Galaxy S21 FE 5G
Samsung Galaxy S21 FE 5G
f-c68b67ae-1f33-4151-9ac7-591298c052dc
f-120aebaa-22d2-4870-907a-0d990f492980
f-f9b548ae-8ff6-4d36-aa3a-e63e2300ab78
f-bab98cda-7229-4e94-8731-6ed34ceae283
f-569f3938-2a28-4395-b033-46570d339893
f-2239dbc3-5167-46f6-85e6-a1f4479872d5
Can you make a voice call?
