Galaxy S21+
Samsung Galaxy S21+
f-2697067d-2fe0-4eeb-a866-9870549b13de
f-bfa4256f-854d-4abe-935d-5b03d6036c9e
f-75758800-6ea9-4be7-bc4a-dc0aa2ef6b10
f-29368725-0aa1-404b-8a70-059cedecd2c1
f-c5103a1a-66a8-41f3-a05d-f542b2b4f08b
f-414e413a-2748-4eca-8ea6-0ca32f715927
Solution 4 of 6: You're trying to check your voicemail when abroad
The default voicemail number can only be used if you're calling from your own network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
