Galaxy S21+
Samsung Galaxy S21+
f-2697067d-2fe0-4eeb-a866-9870549b13de
f-bfa4256f-854d-4abe-935d-5b03d6036c9e
f-75758800-6ea9-4be7-bc4a-dc0aa2ef6b10
f-29368725-0aa1-404b-8a70-059cedecd2c1
f-c5103a1a-66a8-41f3-a05d-f542b2b4f08b
f-414e413a-2748-4eca-8ea6-0ca32f715927
Solution 2 of 4: Automatic mobile data usage is turned on
You can set your phone to use mobile data automatically when the connection to the Wi-Fi network is weak. To turn automatic use of mobile data on or off, you need to turn on mobile data.
Step 1 of 9
Step 2 of 9
Press Connections.
Press Connections.
Step 3 of 9
Press Connections.
Press Wi-Fi.
Press Wi-Fi.
Step 4 of 9
Press Wi-Fi.
Step 5 of 9
Step 6 of 9
Press Advanced.
Press Advanced.
Step 7 of 9
Press Advanced.
Step 8 of 9
Press the indicator next to "Switch to mobile data" to turn the function on or off.
Step 9 of 9
