Galaxy S21 Ultra
Samsung Galaxy S21 Ultra
f-646f8cbf-50e5-4dfa-aa94-eaa827c9e74f
f-f53045ad-2e18-472d-a60c-38c529b09004
f-748b4cde-3223-4c13-ae3a-63462ca92f0e
f-c32d786b-a427-4c1d-a707-e500a4bc8001
f-6a2cdb09-d6dd-4565-a99b-dff3c3c94109
f-f003af5f-47d0-4096-89bb-2dc1aa89d2c2
Solution 2 of 4: Automatic mobile data usage is turned on
You can set your phone to use mobile data automatically when the connection to the Wi-Fi network is weak. To turn automatic use of mobile data on or off, you need to turn on mobile data.
Step 1 of 9
Step 2 of 9
Press Connections.
Press Connections.
Step 3 of 9
Press Connections.
Press Wi-Fi.
Press Wi-Fi.
Step 4 of 9
Press Wi-Fi.
Step 5 of 9
Step 6 of 9
Press Advanced.
Press Advanced.
Step 7 of 9
Press Advanced.
Step 8 of 9
Press the indicator next to "Switch to mobile data" to turn the function on or off.
Step 9 of 9
