Galaxy S22
Samsung Galaxy S22
f-f52ed4a8-6973-40ed-ac96-6a905eb531ac
f-29561bd4-ba7b-4a79-9fdc-8fcd31a0cd3f
f-2fad90b2-fd13-4d94-a054-55b46d334fec
f-fdd8196d-835e-418f-ab54-b9b2802beba9
f-0c9d7f83-e071-4178-9c86-60398c5ef359
f-ff06fa90-aa65-4b5e-87b5-1b3d54bf8f98
Can you make a voice call?
