Galaxy S22 +
Samsung Galaxy S22 +
f-55360b6d-a347-43f4-a15b-fc8883e35b38
f-4f7d54a6-4fc3-4675-b32f-6969fe9b69ae
f-7a42a465-3b10-42a1-8274-aa77fdb02c9c
f-c0fb30e9-f1d3-429d-b10b-1b509955c62c
f-0fad6bf4-f42b-483b-97fd-e94229fd6b6f
f-422e72b2-093e-41b1-af46-88d4b3d4e9e5
Solution 4 of 6: You're trying to check your voicemail when abroad
The default voicemail number can only be used if you're calling from your own network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
