Galaxy S22 Ultra
Samsung Galaxy S22 Ultra
f-8c67b36b-b278-4ddb-b65e-500a550218b9
f-e510a8da-c96c-4e35-a001-32ef49af2d28
f-bb27c162-83be-4057-9d55-2eb9fc4e092c
f-46c0e823-e6a1-4668-9bd7-909b7e166822
f-a1c657a7-ca34-4536-aafe-ca2091ff1d5b
f-0e5ea35b-e48d-46c9-92ca-4475a33fa45e
Can you make a voice call?
