Galaxy S23
Samsung Galaxy S23
f-5ed58648-62ad-4ecb-b649-59f88a91d3fc
f-5ad75b8f-43c8-48b7-8d65-040d6ba9c6f4
f-98ece27f-40c5-4d97-b222-22429299c0bd
f-40c7f2cc-7dfb-4a6f-9597-617805517bc7
f-9852149b-96cf-4466-aa56-3ad339b6907b
f-f7cdcb5c-e843-4bfe-9078-859ac206ff8e
Can you make a voice call?
