Galaxy S23 FE
Samsung Galaxy S23 FE
f-3914666a-cbd0-4e90-9a68-38107ce7f77f
f-bdd2acd8-ef76-4af9-b1e9-9d11edf0c287
f-254ffc76-b385-4d78-8fae-7d7fab23b8ff
f-e1802c4f-1cf2-499f-a8d9-edba79f4c9cd
f-95f6b300-02d8-4a42-becf-7f9bd9abb69f
f-b7483e17-3459-464d-bf86-c54c51e1ebf5
f-bd45b7c8-45d1-442d-89a5-d35fb6c70843
f-78e70d77-6393-4965-abbb-bf4f94962dfd
Can you make a voice call?
