Galaxy S23 Plus
Samsung Galaxy S23 Plus
f-66cbdf2b-9f20-41ef-a6c2-dd2604e1fea5
f-b8403258-a132-4482-8a94-28f7d7648cf8
f-a63805e1-ee40-4227-b0ab-aff2db6e3079
f-b246013f-e324-4f53-ad9b-7d13a412ad3b
f-96c2f8f6-d99b-4eb5-ac53-0028f1b1baa7
f-bd4fced5-f446-4ad8-8dfa-70b8eadf860b
Can you make a voice call?
