Galaxy S23 Plus
Samsung Galaxy S23 Plus
f-66cbdf2b-9f20-41ef-a6c2-dd2604e1fea5
f-b8403258-a132-4482-8a94-28f7d7648cf8
f-a63805e1-ee40-4227-b0ab-aff2db6e3079
f-b246013f-e324-4f53-ad9b-7d13a412ad3b
f-96c2f8f6-d99b-4eb5-ac53-0028f1b1baa7
f-bd4fced5-f446-4ad8-8dfa-70b8eadf860b
Selecting dual SIM settings
When you insert two SIMs into your phone, you can make calls and send and receive messages from both SIMs. You can also select a default SIM for mobile data usage.
Step 1 of 16
Step 2 of 16
Press Connections.
Press Connections.
Step 3 of 16
Press Connections.
Press SIM manager.
Press SIM manager.
Step 4 of 16
Press SIM manager.
Press the required SIM.
Step 5 of 16
Press the indicator to turn use of the SIM on or off.
Step 6 of 16
If you turn on use of the SIM, press Turn on.
Step 7 of 16
If you turn off use of the SIM, press Turn off.
Step 8 of 16
Press the Return key.
Step 9 of 16
Press Calls.
Press Calls.
Step 10 of 16
Press Calls.
Press the required setting.
Step 11 of 16
Press Messages.
Press Messages.
Step 12 of 16
Press Messages.
Step 13 of 16
Press Mobile data.
Press Mobile data.
Step 14 of 16
Press Mobile data.
Step 15 of 16
Step 16 of 16
