Galaxy S24 FE
Samsung Galaxy S24 FE
f-a5e48ff0-fc0a-4eef-9bb5-0a33aae1a7a4
f-87b405f5-d3b3-4515-8f16-855c8edd3bb5
f-8d27c797-0cf5-435d-af7f-ca202f93ca5f
f-f5180892-3e9e-4925-be90-9aa8a4ff29be
f-e3eed697-25a7-4aae-8e42-9b045b6c24e8
f-35b19538-64ba-427a-8ef2-a351f0027d2c
f-7409c065-e65f-428d-b23b-6d101dcc1b77
f-36275e26-12f9-4ef3-bdb4-1cc76312af67
Can you make a voice call?
