Samsung Galaxy S24 FE
Solution 2 of 3: Your phone doesn't turn on correctly
Press and hold the Side key until your phone is turned on.
If you're asked to key in your PIN, do so and press OK. The default PIN is 1111.
Simultaneously, press and hold the Side key and the lower part of the Volume key.
Press Power off.
Press Power off.
