Galaxy S24 Plus
Samsung Galaxy S24 Plus
f-11c14b89-c6ed-4baf-a808-63318f5ecf5d
f-4f312ab3-7549-4e4d-8d8e-fa7a897c8830
f-a2bab2bf-5994-4060-a627-7a1f5bccd808
f-6d8f8090-ab68-40cf-8d35-6b0127c14db2
f-20f471ed-7fcb-4f91-8ea3-9a793ccc3bc5
f-9f4e76f0-fe06-4767-8a83-b67bc435c223
f-18eb6fd3-ff8d-4b92-aa03-73163bdd2b58
f-804f84ec-c88b-49cb-ad29-eec55bcd7463
Can you make a voice call?
