Galaxy S24 Ultra
Samsung Galaxy S24 Ultra
f-01961826-dceb-41d4-b5c2-33b461bff33d
f-b274d0e9-eeb1-4ba0-b48b-237d35bace21
f-c3c16a6f-3267-418b-b8d8-b72d75af797a
f-f7ebff1a-c51e-4a98-aac2-ea8f5764a315
f-79766f2e-ae38-4008-aa2c-ce8e6b888adf
f-e871ec49-fa44-4e3e-9a05-28273e553675
f-eef3b6f4-5503-42a0-83d3-c1e015c4d4e9
f-3c619efa-f3e4-4955-90c2-07dfc53ba772
Can you make a voice call?
