Galaxy S25
Samsung Galaxy S25
f-c2864d8f-9aac-4728-9241-713f6b3e17f4
f-bf419195-bfc3-4af5-ba86-45cc8989e251
f-ae9e0e9d-d34e-427a-b3a1-b2ead7dcaaca
f-78aa829a-1f7f-4ebe-9ece-6f7017748183
f-dd5c31c7-96c7-4b21-920d-219955ba2a30
f-21e4fd44-ba00-4c80-8f00-27f41182f7db
Can you make a voice call?
