Galaxy S25 Edge
Samsung Galaxy S25 Edge
f-0249f935-2d00-4e9f-874c-3bcdea290e61
f-7dcc0e6e-9d38-4dee-975f-a32aca6d910d
f-b3f0aeae-0e5c-4c26-b4d5-2701c8f683f6
f-988becb8-64db-40a0-b7ed-5798aedd6eff
f-3e0168eb-61f0-432d-87eb-58af094b7091
f-ef5a668a-ada2-41f5-a531-c0193256c607
Can you make a voice call?
