Galaxy S25 Edge
Samsung Galaxy S25 Edge
f-0249f935-2d00-4e9f-874c-3bcdea290e61
f-7dcc0e6e-9d38-4dee-975f-a32aca6d910d
f-b3f0aeae-0e5c-4c26-b4d5-2701c8f683f6
f-988becb8-64db-40a0-b7ed-5798aedd6eff
f-3e0168eb-61f0-432d-87eb-58af094b7091
f-ef5a668a-ada2-41f5-a531-c0193256c607
Solution 1 of 4: Automatic mobile data usage is turned on
You can set your phone to use mobile data automatically when the connection to the Wi-Fi network is weak. To turn automatic use of mobile data on or off, you need to turn on mobile data.
Step 1 of 9
Step 2 of 9
Press Connections.
Press Connections.
Step 3 of 9
Press Connections.
Press Wi-Fi.
Press Wi-Fi.
Step 4 of 9
Press Wi-Fi.
Step 5 of 9
Step 6 of 9
Press Intelligent Wi-Fi.
Step 7 of 9
Step 8 of 9
Press the indicator next to "Switch to mobile data" to turn the function on or off.
Step 9 of 9
