Samsung Galaxy S25 Edge
Solution 4 of 4: Automatic update of apps via mobile network is turned on
Press Play Store.
Press the profile icon.
Press Network preferences.
Press Auto-update apps.
To turn on automatic update of apps using mobile network, press Update all apps over Wi-Fi or mobile data.
To turn on limited update of apps using mobile network, press Update with limited amount of mobile data.
To turn on automatic update of apps using Wi-Fi, press Update over Wi-Fi only.
