Galaxy S25+
Samsung Galaxy S25+
f-7f6df469-55dd-45a4-aede-2f98cb59c933
f-0e781593-fd80-4376-a8fc-23c9bae72ee8
f-16097085-017e-4153-a4a1-109d2b5a5339
f-15617784-9ba0-4a46-b4ff-cb4993830802
f-2d58dfed-df76-4082-a411-05b1ff0fcd58
f-ee2861e4-7120-4c8d-931c-a185300f9e65
Can you make a voice call?
