Galaxy S25 Ultra
Samsung Galaxy S25 Ultra
f-12304bfe-775f-4484-9884-117179cf2526
f-bc4167b2-cced-43f3-b104-0a24a0655fb6
f-2925e249-1299-42f2-95fc-9e6c0888015a
f-589ed901-16a2-42a9-be93-87a965f5e072
f-fbb1d2de-e7e0-4a6a-a81f-ac1124e128e9
f-c91256d9-9637-4233-af6a-865fc671b375
Can you make a voice call?
