Galaxy S26
Samsung Galaxy S26
f-9469e9f7-f607-45c4-893c-50e448745796
f-a4dfb8be-8af9-4aa0-9a9e-a4c70247a762
f-2c53529b-c648-4f63-a70a-d92a1e965f89
f-fb4a9bdd-21de-49bc-a82c-f9c337759f34
f-d00242ca-25ea-46b5-a69d-9899d6d0d413
f-74f6b71d-5957-43f5-9b71-cc078fad3295
f-b88fe78e-956d-47e7-b5ae-57ed94b99849
f-84e90586-02ad-4f5b-9c59-faf50ba9df14
Can you make a voice call?
