Galaxy S26+
Samsung Galaxy S26+
f-903eba60-99b1-40c3-984e-e87b4aa48e2e
f-fdc67a4b-4f3e-4c04-a0df-4f2b57455692
f-5aca7394-41d1-4bcf-964f-39778ce64f69
f-d0c23809-f1e8-4c5e-b260-9f4271c07444
f-42d830d7-d85b-46bf-8f6d-8bebb94bfdd0
f-9736b515-4ccb-4c54-85e7-657a16f0b14c
f-b5a8aeaf-8970-41fc-83b7-0390b9eed86d
f-e440bf31-80b2-45a4-8bfb-57816d5dba6b
Can you make a voice call?
