Galaxy S26+
Samsung Galaxy S26+
f-903eba60-99b1-40c3-984e-e87b4aa48e2e
f-fdc67a4b-4f3e-4c04-a0df-4f2b57455692
f-5aca7394-41d1-4bcf-964f-39778ce64f69
f-d0c23809-f1e8-4c5e-b260-9f4271c07444
f-42d830d7-d85b-46bf-8f6d-8bebb94bfdd0
f-9736b515-4ccb-4c54-85e7-657a16f0b14c
f-b5a8aeaf-8970-41fc-83b7-0390b9eed86d
f-e440bf31-80b2-45a4-8bfb-57816d5dba6b
Solution 2 of 3: Your phone doesn't turn on correctly
Press and hold the Side key until your phone is turned on.
Step 1 of 5
If you're asked to key in your PIN, do so and press OK. The default PIN is 1111.
1111
1111
Step 2 of 5
Simultaneously, press and hold the Side key and the lower part of the Volume key.
Step 3 of 5
Press Power off.
Press Power off.
Step 4 of 5
Press Power off.
Press Power off.
Press Power off.
Step 5 of 5
Press Power off.
