Galaxy S26 Ultra
Samsung Galaxy S26 Ultra
f-821650c0-c578-4a07-944a-e71496445501
f-bff0e0df-786d-468a-a275-3062fcfba55e
f-e9d6ed08-dec2-4844-8e73-1e9b2963e54c
f-5fada14f-2f4a-4db7-a1f9-c9409d1dc8db
f-4f8cc684-177a-416b-b35a-62112a744d66
f-71e7e71f-6d00-48ed-9eae-66dbc307f015
f-b80fd9c6-1e46-4c10-8289-17fda8598f22
f-fe5acd42-e178-4044-9e11-a85e8116741e
Selecting ring tone
You can select the ring tone you want to hear when you get a call.
Press Sounds and vibration.
Press Ringtone.
Press Ringtone.
Press Ringtone.
Press the required ring tones to hear them.
Once you've found a ring tone you like, press the Return key.
To use a different ring tone than the default ones, press the add ring tone icon and follow the instructions on the screen to select the required ring tone.
