Galaxy S26 Ultra
Samsung Galaxy S26 Ultra
f-821650c0-c578-4a07-944a-e71496445501
f-bff0e0df-786d-468a-a275-3062fcfba55e
f-e9d6ed08-dec2-4844-8e73-1e9b2963e54c
f-5fada14f-2f4a-4db7-a1f9-c9409d1dc8db
f-4f8cc684-177a-416b-b35a-62112a744d66
f-71e7e71f-6d00-48ed-9eae-66dbc307f015
f-b80fd9c6-1e46-4c10-8289-17fda8598f22
f-fe5acd42-e178-4044-9e11-a85e8116741e
Solution 1 of 2: Wi-Fi hotspot isn't used correctly
When you use your phone as a Wi-Fi hotspot, you can share your phone's internet connection with other devices via Wi-Fi. To use your phone as a Wi-Fi hotspot, you need to set up your phone for internet.
Step 1 of 17
Step 2 of 17
Press Connections.
Press Connections.
Step 3 of 17
Press Connections.
Press Mobile Hotspot and Tethering.
Step 4 of 17
Press Mobile Hotspot.
Step 5 of 17
Press Network name.
Press Network name.
Step 6 of 17
Press Network name.
Press the field below
Step 7 of 17
Press the field below "Network name" and key in the required name.
Press Security.
Press Security.
Step 8 of 17
Press Security.
Press WPA3-Personal to password protect your Wi-Fi hotspot.
Step 9 of 17
Step 10 of 17
Press the field below "Password" and key in the required password.
Press Save.
Press Save.
Step 11 of 17
Press Save.
Press the indicator below
Step 12 of 17
Press the indicator below "Mobile Hotspot" to turn on the function.
Step 13 of 17
Step 14 of 17
Step 15 of 17
Step 16 of 17
Step 17 of 17
