Samsung Galaxy S26 Ultra
Using Privacy display
You can set your phone to make it harder for others to see the content on your screen by reducing the viewing angle.½
Press Display.
Press Privacy display.
Press the indicator next to "Turn on Privacy display" to turn on the function.
Press Conditions for turning on.
Press Apps and follow the instructions on the screen to select the required apps.
Press the indicator next to "PIN, pattern, password" to turn the function on or off.
Press the indicator next to "Notification pop-ups" to turn the function on or off.
Press the Return key.
Press the indicator next to "Maximum privacy protection" to turn the function on or off.
