Galaxy S7
Samsung Galaxy S7
f-d8c8228d-c283-474f-9e9d-26708245c58e
f-87298e1c-8baf-4e5b-b616-0118fbfa7a32
f-c5fa6ed6-833b-47e1-8f75-5ecb5514868a
f-aa506c5c-d0c1-4c48-98dc-b97017887b7e
f-17c90e43-3897-4fd7-9f6e-9bc5092a5baa
Can you make a voice call?
