Galaxy Tab A8
Samsung Galaxy Tab A8
f-491986ed-d7d5-4c04-a2a5-67a7ef463341
f-c046b525-7d09-450c-a9f0-b2fb94cb5f88
f-f53d6fa0-8aae-4ac9-a092-06e2c673fb94
f-86b06000-90b0-49a5-9347-1cb548725024
f-e1f25745-b58c-4bdd-acb9-c9a3b50b39ea
f-45c45408-77d4-4fbd-941c-1a448a5f587e
Can you make a voice call?
