Samsung Galaxy Tab S10 Ultra
Solution 3 of 6: You're trying to check your voicemail from another device than your own
The default voicemail number can only be used if you're calling from your own tablet.
Call 07953222222 to check your voice messages from another phone. Please note that you need to set a PIN before you can check your voice messages from another phone.
