Galaxy Tab S9+
Samsung Galaxy Tab S9+
f-79443638-576a-42ff-b77e-fc18ced745e3
f-9b8f1a59-d9e9-47b6-ab29-bc68f4d41a13
f-3cf9aad6-9597-46d4-bb3b-9554a067e227
f-78f24e12-2472-48da-bdab-6bfad00ae112
f-81426857-0886-4883-86fb-ab7ed3118146
f-457f43bc-046e-4506-bf0f-b9f3747780fc
Can you make a voice call?
