Samsung Galaxy Tab S9+
Solution 2 of 2: Your tablet hasn't been correctly set up for IMAP email
You can set up your tablet to send and receive email messages from your email accounts. Using IMAP, your email messages are kept on the server and are synchronised between all of your devices. You're then able to access your email messages from other devices. To set up your tablet for IMAP email, you need to set up your tablet for internet.
Press Accounts and backup.
Press Manage accounts.
Press Add account.
Press Personal (IMAP).
Press NEXT.
Press NEXT.
If this screen is displayed, you email account has been recognised and set up automatically. Follow the instructions on the screen to key in more information and finish setting up your tablet.
Press the field below "Port" and key in 993.
Press SSL/TLS.
Press NEXT.
Press the field below "Port" and key in 587.
Press SSL/TLS.
Press NEXT.
Press the required setting.
Press NEXT.
Press NEXT.
