Galaxy Tab S9 Ultra
Samsung Galaxy Tab S9 Ultra
f-95da0bc4-0e61-492d-a0f3-d4b64dad9ce7
f-8cf27981-8760-4071-b3db-00d1fbb04e0c
f-045bf405-afeb-46ed-9ffb-b0050a640079
f-aaf2ed0b-8c3a-4262-952c-af8045d06c3b
f-0c8aebda-7728-4054-ad23-e275fcdd9906
f-da990b20-41ef-41ab-8076-5902fd4b48b8
Can you make a voice call?
