Samsung Galaxy Watch7
Using Samsung Health
You can use your smartwatch to register your training and monitor your health. The information is sent to your phone and is automatically synchronised with Samsung Heath.
Press the Samsung Health icon.
Under Daily activity, you can see how far you are from completing your daily activity goals.
The number of steps for the day is displayed below Steps.
Press Steps.
Press Set target.
Slide your finger up or down on the screen to select the required goal.
Press Done.
Press the Return key.
Press Work out.
Slide your finger right or left to select the required activity.
Follow the instructions on the screen to set the required goals.
Press the required activity to start the activity.
Press and hold the Return key to pause an activity.
Press Finish to end an activity.
Press Heart rate.
Press Measure and wait while the smartwatch measures your heart rate.
Press Tag.
Press the required setting.
Press Blood oxygen.
Press Measure.
Press OK and wait while your smartwatch measures your blood oxygen level.
Press Tag.
Press Stress.
Press Measure.
Press the Samsung Health Monitor icon.
Press Blood pressure and follow the instructions on the screen to measure your blood pressure.
Press ECG and follow the instructions on the screen to use the ECG function.
