Galaxy Watch7
Samsung Galaxy Watch7
f-c1901bed-d079-43a9-849b-a1e47b759a5c
f-b202fd47-06ce-4211-abc6-aa47dd50b693
f-24c1c8f7-de8b-4d34-ab86-36647da4eeed
f-accc5b55-2a84-476a-b71b-c93bc92f5251
f-6a7f21a8-9a7c-4e91-b072-f23ef48519a8
f-a386ce93-f106-442e-9b97-0cbe8838cb6e
f-e55cfd38-3d9e-4c18-b413-f97d24f48ae6
Selecting settings for use of mobile network
You can select if you want to use the mobile network on your smartwatch or on your phone by default.
Press Connections.
Press Connections.
Press Connections.
Press Mobile networks.
Press Auto.
Press Auto.
Press Auto.
If you turn on the function, your smartwatch will automatically switch between use of mobile network on your smartwatch or on your phone.
Press Always on.
Press Always on.
Press Always on.
If you turn on the function, your smartwatch will use the mobile network even when connected to your phone via Bluetooth.
Press Always off.
Press Always off.
Press Always off.
If you turn off the function, you can’t send or receive messages, use the call function or use mobile data on your smartwatch.
