Galaxy Z Flip
Samsung Galaxy Z Flip
f-87321f46-a363-4f1a-8623-588cddaffa86
f-e757ca9c-c688-4143-a359-268f9fcf3480
f-1aab6645-695f-4897-a44c-025273c76a78
f-5b316b46-fbfa-49d5-8f09-bde3227a2516
f-295f8b0c-a912-4ae9-9c16-a59db5fe6891
f-93a93baa-0109-419e-bd83-b64694ae9f5f
Solution 2 of 4: Automatic mobile data usage is turned on
You can set your phone to use mobile data automatically when the connection to the Wi-Fi network is weak. To turn automatic use of mobile data on or off, you need to turn on mobile data.
Step 1 of 9
Step 2 of 9
Press Connections.
Press Connections.
Step 3 of 9
Press Connections.
Press Wi-Fi.
Press Wi-Fi.
Step 4 of 9
Press Wi-Fi.
Step 5 of 9
Step 6 of 9
Press Advanced.
Press Advanced.
Step 7 of 9
Press Advanced.
Step 8 of 9
Press the indicator next to "Switch to mobile data" to turn the function on or off.
Step 9 of 9
