Galaxy Z Flip4
Samsung Galaxy Z Flip4
f-ad0056c4-0e7f-4916-bf8c-52e6258e738b
f-ff866d40-588b-499b-9998-3b20f5b6697a
f-7661c671-8d6d-436c-ba38-8e5ab6c91e59
f-8dbea5ba-e465-4ead-a00b-e948a7a85cc0
f-d637c4b5-1c35-47c4-9ed9-3dd5237cf91d
f-995d3e69-ea7e-403e-abdf-05232e902de3
Can you use Wi-Fi?
