Galaxy Z Flip5
Samsung Galaxy Z Flip5
f-89a9deea-7dcd-49ac-b72f-d4a139408111
f-f75f01c3-9ebd-4767-99d7-0d77b5b0245f
f-fb2ef7d5-9cd4-4e07-9c12-7dd61647e8b0
f-678f801c-1ffa-4e02-8ed1-58310866679f
f-c9c9bc54-1226-4d73-a999-d3769c91f86f
f-318301da-8870-4821-9f49-53714449b167
Can you make a voice call?
