Galaxy Z Flip5
Samsung Galaxy Z Flip5
f-89a9deea-7dcd-49ac-b72f-d4a139408111
f-f75f01c3-9ebd-4767-99d7-0d77b5b0245f
f-fb2ef7d5-9cd4-4e07-9c12-7dd61647e8b0
f-678f801c-1ffa-4e02-8ed1-58310866679f
f-c9c9bc54-1226-4d73-a999-d3769c91f86f
f-318301da-8870-4821-9f49-53714449b167
Solution 4 of 4: Wi-Fi calling is turned off
When Wi-Fi calling is turned on, you can make and answer calls using a Wi-Fi network when you're in an area with little or no network coverage. To turn on Wi-Fi calling, you need to establish a connection to a Wi-Fi network, select 4G (LTE) as network mode and follow the steps below. You can also visit the EE web page for more information about Wi-Fi calling.
Step 1 of 5
Step 2 of 5
Press Connections.
Press Connections.
Step 3 of 5
Press Connections.
Step 4 of 5
Press the indicator next to "Wi-Fi Calling" to turn the function on or off.
Step 5 of 5
