Galaxy Z Flip7
Samsung Galaxy Z Flip7
f-eafb9da5-8750-4fef-9dc1-f725f5a7feba
f-a11dae12-8f1b-46b5-90be-089309c402b1
f-b5831145-f08f-4974-b925-a37657fac740
f-7530b2ce-d864-4400-8d6b-a7d32f13d1b2
f-41d1016f-92fd-49b0-a59c-1f80c6b00022
f-c3b6b92f-4355-420c-822a-109bd44ae8ef
f-427e4f8b-31ae-40f7-afc9-7ad76d2c0535
f-b7563523-dccc-4ee8-bd43-9552a241ac3a
Can you make a voice call?
