Galaxy Z Flip7 FE
Samsung Galaxy Z Flip7 FE
f-d0956f4f-c453-42bf-8bc7-49431b6d1052
f-12226dc9-ac9f-4454-9791-75acc499dabd
f-5c9305be-c85d-44c5-b56b-efc9f6a9cb00
f-d3417c21-b69c-406b-b6f0-4515f239882e
f-bf6ad10e-fc9c-4dad-869f-0cb37069d5d4
f-25a90496-feed-4dd2-9a06-8b83b924a717
Can you make a voice call?
