Galaxy Z Flip8
Samsung Galaxy Z Flip8
f-5aedd798-186f-4e71-90fc-4e1513546251
f-6bd5226d-d9fc-45e3-8a5c-6b0c038c2ab6
f-5b509b74-6a5d-4388-a56e-6005c3fc8da2
f-a1a07bb0-ef17-4106-8bf6-dc195b92229f
f-2d94f1d6-cd64-4b03-accc-876c58b0487f
f-8e585268-cefb-4603-8304-d551c6b3f589
f-3217fe45-6c6f-4ca2-a501-0a9520c867df
f-f50ae5aa-b891-40ef-b8ad-1ded268abacc
Can you make a voice call?
