Galaxy Z Fold4
Samsung Galaxy Z Fold4
f-97b65d20-bf87-4de6-9ba6-0d36dac9fa94
f-eb1685c3-6e04-409f-9765-e3edb43e258d
f-09cc7d62-0701-40bb-a290-9268565b3ca1
f-3fb25710-47c9-4e08-9849-fdad0a58afa5
f-c6b84a4a-08db-4226-b48d-f7ae9ba9af88
f-4278d70c-1431-4496-a687-4cdd4c795182
Can you make a voice call?
