Galaxy Z Fold5
Samsung Galaxy Z Fold5
f-84fe8186-7b85-430f-945a-fd3aeb752513
f-70f4573f-b7d2-4bc3-bd4b-dc0db7478caa
f-882029de-3189-4279-99b9-86c8e2746f45
f-dc858432-a497-4886-9553-d1cc9a02b75d
f-2b620b3b-b1b7-4c06-9e23-e5388b1db8aa
f-6b3d18ff-f3bc-4509-b583-9e148e3c05e0
Can you make a voice call?
