Galaxy Z Fold7
Samsung Galaxy Z Fold7
f-4d7df143-a043-4355-8189-f4c569f3d476
f-0edb012e-4d2e-41eb-b90e-683fd507aca3
f-111317e2-25ea-4f70-a358-512755cbec3c
f-081837d6-3dad-41a1-8236-ec480cd935cb
f-810f60d9-623e-4310-a406-d73bffcf5b9c
f-fa0f5d95-2165-4284-aa5f-be193920f00c
f-2b0f5674-8006-4d0e-b751-e6f972d8b047
f-12ea3486-67a5-4388-8102-be79e44fb677
Can you make a voice call?
