Galaxy Z Fold8
Samsung Galaxy Z Fold8
f-60e27214-6991-4918-8361-21053f4ac47b
f-3d9c5f83-72eb-4fcb-a829-761427cc2b0a
f-8e1b67d4-0a3a-4f9d-921d-ed48cf5684e6
f-a1fe1c4b-3b9f-419c-bfd5-4c5a63a21ed4
f-e31aa5b6-9295-4cc2-9651-911cee71a6f0
f-0662be3c-2f11-4693-9442-182f29a385b1
f-949ff82c-fe8f-4dcf-ba09-9c83e925b540
f-ccba10b1-309d-4e57-8f24-d2228a1f8e05
Selecting ring tone
You can select the ring tone you want to hear when you get a call.
Press Sounds and vibration.
Press Ringtone.
Press Ringtone.
Press Ringtone.
Press the required ring tones to hear them.
Once you've found a ring tone you like, press the Return key.
To use a different ring tone than the default ones, press the add ring tone icon and follow the instructions on the screen to select the required ring tone.
