Sony
Xperia 1 VI
Sony Xperia 1 VI
f-09259b8d-382d-495b-9321-94b7b3fb7338
f-8fe403b2-cebe-4a85-b2d0-8b269b74e259
f-faf80ea9-1a4a-48e9-9a06-0e1112b1d377
f-60b4b65c-fe2a-4c2a-bcb3-360fe3d88dbc
f-709314bb-86ba-45ea-a5a7-7b97cf0ec02a
f-17181dbb-8b66-42bd-81a0-c602e0efb264
f-9f06db35-d175-4800-bc1e-0249759ca29d
f-5502f6df-0e69-4889-b991-cc77dcc8b08f
Solution 6 of 6: You're trying to check your voicemail when abroad
The default voicemail number can only be used if you're calling from your own network.
Call +447953222222 to check your voice messages when abroad. Please note that you need to set a PIN before you can check your voice messages when abroad.
