Sony
Xperia 1 VI
Sony Xperia 1 VI
f-09259b8d-382d-495b-9321-94b7b3fb7338
f-8fe403b2-cebe-4a85-b2d0-8b269b74e259
f-faf80ea9-1a4a-48e9-9a06-0e1112b1d377
f-60b4b65c-fe2a-4c2a-bcb3-360fe3d88dbc
f-709314bb-86ba-45ea-a5a7-7b97cf0ec02a
f-17181dbb-8b66-42bd-81a0-c602e0efb264
f-9f06db35-d175-4800-bc1e-0249759ca29d
f-5502f6df-0e69-4889-b991-cc77dcc8b08f
Solution 2 of 2: The password used on the other device is incorrect
To use your phone as a Wi-Fi hotspot, you need to key in the password you selected when you set up your phone as a Wi-Fi hotspot on the other device.
Check the password for the Wi-Fi hotspot on your phone and key in the correct password on the other device.
