Sony Xperia 10
Copying contacts between your SIM and your phone
You can copy contacts between your SIM and phone. This way, you won't lose your contacts if you change your SIM or phone.
Press Contacts.
Press Import.
Press Import from SIM card.
Press the drop down list.
Press Locally saved contacts.
Press IMPORT.
Press Export.
Press Export to SIM card.
Press OK.
Press Mark all.
Press EXPORT.
If you want to keep existing contacts saved on your SIM, press Add contacts.
If you want to replace existing contacts saved on your SIM, press Replace all contacts.
Press OK.
