Sony
Xperia 10
Sony Xperia 10
f-7aabb6b1-2407-4f16-813d-95922d385bee
f-7f8006f1-379c-4ffc-bb11-ac4e93eba3a9
f-d724d92d-8ef4-49af-8950-1132e7a199fa
f-324d67a8-ee63-4c6a-88e2-9401f679f97d
f-8b5d92cb-1229-4725-a840-ea978a36bd6d
f-9d8a0fc0-cc50-4f6a-a4c5-7125f860fdb7
Can you make a voice call?
